AOC Agon AG322QC4 Curved FreeSync 2 Gaming Monitor Review: HDR Accuracy On a Budget
Compared to the Samsung CHG70 32" I am curious which has the better image quality. Spec wise they seem very similar.
I wish more HDR monitors came with Gsync. So far the only ones I've seen are the nearly $2000 ones. Nobody seems to make a 2k HDR monitor with Gsync that I've seen. 4K seems unnecessary on a 27" screen.
I haven't looked much into that monitor, but I believe it has an SRGB mode, which could be important if you need colors to match how they appear on a regular monitor, rather than having everything appear oversaturated.
Thanks for the test, i just dont understand one thing :
"DisplayPort or HDMI, but, as noted above, HDR only works with the latter"
Why???
displayport 1.2 and hdmi 2.0 both support QHD at 144Hz and HDR
Wait, you CAN'T use HDR on DisplayPort? I just bought this monitor last week and i'm using on DisplayPort.
You can. I am using HDR on Display Port.
However when Windows is set to auto detect for HDR and the monitors HDR auto detect feature also on, these 2 features dont play well with each other and its caused some crashes
