11blackjack11
105
recently got a RTX 2080 ti for 4k gaming had it for 2 days now i think and i was wondering theses fan speeds and the temps were normal?
the fan speed for all 3 fans for the card well pretty much be at 60% with temps of mid 60c or 70c the card i got is
EVGA GeForce RTX 2080 Ti FTW3 Ultra Gaming, 11GB GDDR6, iCX2 & RGB LED Graphics Card 11G-P4-2487-KR
D
Those are normal GPU parameters, when the card is under load. Gpu core/MEM clocks will boost when there the card is stressed, due to the GPU BOOST feature/technology from NVIDIA.
awhile ago i asked if temps were normal i was getting 70c with fans ramping up to 70%
also wanted to know if these memory temps were within reason memory temp 2 and 3 are 85c and 84 c
most thing im concerned about is the Gpu memory clock it goes up to 7000mhz while gaming
and yeah it goes down to 400 when idle
the card im running is
From where are you getting 7000Mz vale ? You GPU should have the following Memory Clock values.
Memory Clock: 1750 MHz.
14000 MHz effective.
stick with 1 thread. don't spam the forum
posted a couple threads about my card its a new one EVGA RTX 2080 TI FTW3 ultra cost me a pretty penny so i made a few posts making sure it ran perfectly
again im posting about clock speeds to see if they were at a normal rage for this card im getting a GPU clock speed of 1980mhz of course i see it dip down a bit
and im getting 7000mhz on the memory playing the witcher 3 the card runs hot at around mid 70c with a set fan speed of 75%
the clock speed varies i believe depending on the game i play GTA5 i believe i get clocks of 1300mhz cant say for certain it bounces
and for the memory clock its at 5000mhz and ill get temps of 55-69c with a fan speed of 55% but most importantly is 1980mhz and 700mhz
a safe clock for the card? i mean i know the card is a beast mind you i dont overclock the card its currently at stock clock
