[SOLVED] Are these parts compatible?
bignastyid
Thanks for the fast reply. I have two Crucial Ballistix Sport LT 8GB DDR4 PC4-19200.
DDR4 2400 is going to hurt a Ryzens performance. Considering you can currently get a 16Gb kit of DDR4 3200 for $60 I'd ditch that slow 2400 you currently have.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($185.99 @ Amazon)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard ($99.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($59.99 @ Newegg)
Storage: Crucial MX500 500 GB M.2-2280 Solid State Drive ($54.99 @ Amazon)
Video Card: Sapphire Radeon RX 5700 XT 8 GB NITRO+ Video Card ($429.99 @ Newegg)
Case: NZXT H500 ATX Mid Tower Case ($89.98 @ NZXT)
Power Supply: SeaSonic FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($71.98 @ Newegg)
Total: $992.91
Generated by PCPartPicker 2019-11-30 08:22 EST-0500
Reactions: RodroX
RodroX
Notable
Aug 4, 2019
710
206
890
28
Those part are compatible, BUT! depending on how new the stock of that motherboard is, it may happend that the it doesn't come with out of the box Ryzen 3xxx support (meaning the BIOS is kinda old and it won't recognize the Ryzen 3xxx until update it).
If you have an old Ryzen CPU you can get that mobo, update the BIOS with your old Ryzen 1xxx or 2xxx, and then use the Ryzen 5 3600. But if you don't have a previous Ryzen you may need to get a motherboard with BIOS flashback or some of the MSI "MAX" mobos that are supposed to be compatible with Ryzen 3rd gen out of the box. (Heres a round up of the best AM4 mobos out there, with the link to your selected mobo:
View: https://youtu.be/ti38JS8RuPU?t=2110
Alternatives:
- https://pcpartpicker.com/product/jcYQzy/msi-b450-tomahawk-max-atx-am4-motherboard-b450-tomahawk-max
- https://pcpartpicker.com/product/McfFf7/asus-prime-x570-p-atx-am4-motherboard-prime-x570-p
One question, you said you have the RAM already, what kind of RAM do you have? Is this a
tleast a 2x8GB DDR4 3200MHz kit ?
Cheers
Reactions: vMax
Nov 30, 2019
9
Alternatives:
Cheers
Reactions: RodroX
bignastyid
Total: $992.91
Reactions: RodroX
Nov 30, 2019
9
Total: $992.91
thanks for the help
Nov 30, 2019
9
Alternatives:
Cheers
this is my updated List (I decided to buy the ssd locally). What do you think? https://pcpartpicker.com/list/8VnDq3
