Are these parts compatible?
Hi. Those parts are compatible but if you don't mind buying from Amazon I recommend this for a gaming build. Since you're buying a discrete graphics card, there's no real point in getting an APU. If you decide to go with the original build, replace the PSU, GPU, case with the ones I recommended and buy 8GB (2 x 4GB) of RAM (only 2 slots on motherboard).
Case: NZXT Source 210
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146076
$30 after rebate
PSU: CORSAIR Builder Series CX500 500W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
$30 after promo code and rebate
MOBO: BIOSTAR H77MU3 LGA 1155 Intel H77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138358
$50 after rebate
RAM: Patriot Memory Intel Extreme Masters 8 GB (2 x 4GB)
http://www.amazon.com/dp/B008MF3R82/
$32
CPU: Intel Core i3-2105 Sandy Bridge 3.1GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115090
$105
GPU: ASUS HD7850-DC2-2GD5-V2 Radeon HD 7850 2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121651
$170 after rebate
HDD: Unchanged
$50
The total of this build is $467 after promo code and rebates. If you're willing to spend $12 over your budget, I highly recommend the i5-3470 for $180 from Amazon.
