Are these parts compatible
omaroma11
332
Hello I was wondering if these parts were compatible and if I could make them better somehow thanks :non:
NZXT Phantom 410 CA-PH410-B1 Red Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146086
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
ASUS VK248H-CSM Black 24" 2ms (GTG) HDMI Widescreen LED-Backlit LCD Monitor 250 cd/m2 ASCR 50000000:1 Built-in Speakers&Webcam
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236261
ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767R
ASUS ENGTX550 TI DC TOP/DI/1GD5 GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121434
SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
hec ZEPHYR ZEPHY580MX 580W Continuous @ 40°C ATX12V V2.3 / SSI EPS12V SLI Certified CrossFire Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817339034
Crucial Ballistix 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model BLT2KIT2G3D1869DT1TX0
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148559
AMD FX-4100 Zambezi 3.6GHz (3.8GHz Turbo) Socket AM3+ 95W Quad-Core Desktop Processor FD4100WMGUSBX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
THANK YOU :)
I adjusted my build a bit to include OS and monitor but yeah I hate that PC Part Picker always lists Micro Center - that's not always an option for everybody.
Try this:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99 @ Microcenter)
Storage: Samsung Spinpoint F3 1TB 3.5" 7200RPM Internal Hard Drive ($74.99 @ Newegg)
Video Card: Sapphire Radeon HD 7850 2GB Video Card ($258.44 @...
They will all work together but...
I do have some questions/suggestions:
Is there a particular reason you went with an AMD CPU? AMD gets beat by Intel at almost every price point.
I would recommend getting 8gb (2x4gb) of DDR3 1600mhz RAM. G.Skill make some good kits, I particularly like their ARES line because they have a lower profile and don't conflict with the CPU heat sink like some other kits.
I would replace that PSU with either: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027 or http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030 . They are both cheaper and from more reputable brands.
Not necessarily. How much are you looking to spend overall on that system? The FX is such a poor choice when even the lowest end Intel CPUs completely eclipse them in just about every single category.
Just because I can't get enough of this.
For $1100 I think I would scrap that whole build and get something like this:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($229.99 @ Newegg)
Motherboard: Gigabyte GA-Z77X-UD5H ATX LGA1155 Motherboard ($188.49 @ Newegg)
Memory: Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1600 Memory ($43.99 @ Newegg)
Video Card: Sapphire Radeon HD 7950 3GB Video Card ($349.99 @ Newegg)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case ($109.98 @ Newegg)
Power Supply: Corsair 650W ATX12V / EPS12V Power Supply ($79.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.99 @ Newegg)
Total: $1125.40
(Prices include shipping and discounts when available.)
(Generated by PCPartPicker 2012-08-03 13:10 EDT-0400)
A little bit over $1100 but way better CPU, motherboard, PSU, GPU, RAM, you name it. If you want to keep it under $1100 replace the video card with the 7870.
CPU: Intel Core i5-2500K 3.3GHz Quad-Core Processor ($159.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.99 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1333 Memory ($49.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($80.14 @ Amazon)
Video Card: Sapphire Radeon HD 7870 2GB Video Card ($284.99 @ Newegg)
Case: Cooler Master Elite 430 ATX Mid Tower Case ($39.99 @ SuperBiiz)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.98 @ Outlet PC)
Monitor: Asus VH236H 23.0" Monitor ($149.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($88.73 @ Amazon)
Total: $1106.77
(Generated by PCPartPicker 2012-08-03 13:36 EDT-0400)
**Monitor** | [Asus VH236H 23.0" Monitor](http://pcpartpicker.com/part/asus-monitor-vh236h) | $149.99 @ Newegg
**Operating System** | [Microsoft Windows 7 Home Premium SP1 (64-bit)](http://pcpartpicker.com/part/microsoft-os-gfc02050) | $88.73 @ Amazon
| | **Total**
| Prices include shipping and discounts when available. | $1106.77
| Generated by PCPartPicker 2012-08-03 13:35 EDT-0400 |
Couple notes:
-Stupid PC partpicker always puts MicroCenter price first for Intel CPUs. That price is In-store only. Meaning you have to actually live near one to buy it that cheap. Its $200-220 everywhere else.
- Yes I went with an Sandy Bridge 2500K instead of Ivy 3570K. Why? Because its usually cheaper, and Ivy Bridge despite being newer, offers absolutely no improvement over Sandy for gamers (less than 1% improvement) and yet the Ivy typically costs more.
- CoolerMaster 212+ CPU cooler instead of 212 Evo. They perform almost identical, but the 212+ is $10 cheaper.
- No I didn't go with the case you wanted, you can drop down on the video card a little bit if you like. The next step down would be the 7850. Still a pretty good video card, overclocks well enough to perform on par with a stock GTX 570.
Try this:
Video Card: Sapphire Radeon HD 7850 2GB Video Card ($258.44 @ Mwave)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case ($99.99 @ Amazon)
Total: $1107.10
(Generated by PCPartPicker 2012-08-03 13:51 EDT-0400)
