Question ARGB help! Can I connect another argb controller to the argb controller that comes with ml240r
Pc_Gamer_0426
62
I'm planning to buy the cm ml240r in preparation for summer, I know that it comes with a controller and I can mount it in in my x470 gaming plus mobo. I'm planning to get additional argb fans and the ones I found is called tecware arc spectrum (https://dynaquestpc.com/collections...rum-f3-starter-kit-4x120mm-8port-hub-w-remote) it's really a good budget option for argb fans but the problem is the fans have its own custom 6 pin connector which only works with the controller it comes with the kit. The controller has a 3 pin connector for the mobo but my mobo the x470 gaming plus doesn't have a 3 pin rgb connector. I do know that the argb controller that comes with the ml240r has lots of those and I am thinking if I can connect my tecware argb controller to the ml240r argb controller which is then connected to my mobo via the usb adapter.
Latest posts
