[SOLVED] Asking for case advice
danielklabukov
8
Here I am again, asking for your help and advice 😛
-My case is garbage, I want to get a new one.-
°it needs to fit my GPU, a gtx 1070 by Gigabyte, which is 30cm long
°Should have a glass side panel so I can admire my gtx 1070
°Preferably white
Which ones doe you recommend? Why?
Price limit is about 100€
Thanks in advance
I would suggest another cases with better airflow(also it has rgb if you want some colors to your case):
Cooler master td500mesh/Lancoolc II mesh/ Be quiet pure base 500dx/Phanteks p400A digital.
They all have price near the 100euro.
Check the prices in your country.
They will be good for future upgrading.
Cm td500mesh link:
https://nl.pcpartpicker.com/product...troller-atx-mid-tower-case-mcb-d500d-wgnn-s01
*You have it also in black color
Lancool II mesh:
https://nl.pcpartpicker.com/product...-atx-mid-tower-case-lancool-ii-mesh-rgb-black
Be quiet pure base 500dx...
First of all,
Cabinet of a pc is really shows your profession.
If you're a gamer and video editor then you should go with RGB cabinets. There is no restrictions on buying cabinet, like does this part support this cabinet! It's completely depends on your choice. Here are some awesome cabinets for gaming purpose -
1. https://www.amazon.com/NZXT-H510-Ma...tag=wpcentralb-20&ascsubtag=UUwpUdUnU46283YYm
2. https://www.amazon.com/dp/B07FL1D5RV/?tag=tntoday-20
3. https://www.amazon.com/dp/B01NALAFU9/?tag=tntoday-20
4. https://www.antesports.com/ICE-200TG-cabinet.html
Always aware,
Never buy a gaming cabinet with acrylic glass. Always go with tempered glass.
Or,
If you're using your pc for official use then I don't recommend you to go with these cabinets. It's really effects the profession. Just go with a cabinet without RGB lighting.
I hope this will gonna help ya!
Reactions: danielklabukov
Cm td500mesh link:
Lancool II mesh:
Be quiet pure base 500dx:
https://nl.pcpartpicker.com/product/FCK2FT/be-quiet-pure-base-500dx-atx-mid-tower-case-bgw37
Phanteks P400a digital:
https://nl.pcpartpicker.com/product...0a-digital-atx-mid-tower-case-ph-ec400atg_dwt
*You have it also in black color.
*If you will go for the P400a case, you need to remove the Hdd cages in order to insert your gpu(need to remove the hdd when the gpu is over 280mm).
