ASRock A780GXE Help please. Front panel connectors.
Abyssalx
255
I have an ASRock A780GXE and an Antec 300 case. I'm trying to connect the front panel to the board but the connectors don't work right. The Power LED takes up 3 pins, and the board only has 2 for it. There is a place where a 3 pin connector could work, but the book says it's a dummy pin. Can anyone help?
You can re-arrange the pins on the connector. Use a bent staple, safety pin, or small paper clip to slightly bend the little plastic lock and the end and slide the wire out. Then put the wire into the right slot. If you're not sure what I'm talking about then google it :D.
