Question Asrock B550 Steel Legend: Rear type-c port not working properly
Twin-Frozr-1212mV
57
Hello there,
i am wondering why the rear usb c port of my asrock b550 steel legend fails to recognise the majority of my devices (Android phones, audio interfaces, usbc to 3.5mm audio)
My Apple devices seem to charge, but i get no data connection.
I checked different type-c to type-c cables but all of them work as expected on my other machine.
Is this a common asrock mainboard issue, a bios issue on my end or do you recommend opening a ticket at the asrock support for a faulty device?
Best regards 😉
Check and see what BIOS version you're on at this moment of time. Cross reference the BIOS listed on your motherboard support site and see if you've got any BIOS updates pending. As for the platform, what OS are you working with? Check and see if there are any updates pending for said OS as well. Following that, see if reinstalling the chipset drivers for the motherboard in an elevated command, i.e, Right click installer>Run as Administrator, alleviates the issue.
Hi,
I recently updated my bios hoping for a fix but had no luck there so far....
My windows 11 is up to date too :/
I just visited the amd website and deployed their latest b550 chipset drivers (with admin rights), didnt fix it either.
Thanks for your suggestions though :)
This is the summary of the chipset software:
Code:
AMD Chipset Software Install Summary
Name             : AMD Processor Power Management Support
Version          : 8.0.0.13
Install          : Success
Name             : AMD PCI Device Driver
Version          : 1.0.0.90
Install          : Success
Name             : AMD GPIO Driver
Version          : 2.2.0.130
Install          : Success
Name             : AMD GPIO Driver (for Promontory)
Version          : 3.0.0.0
Install          : Success
Name             : AMD PSP Driver
Version          : 5.22.0.0
Install          : Success
Name             : AMD SMBus Driver
Version          : 5.12.0.38
Install          : Success
Didn't fix it.
On the Asrock Webpage i couldn't find anything concerning b550 steel legend usb drivers.
Thanks for your time, much appreciated :)
