[SOLVED] Asrock B550M Pro 4 Storage
Nov 24, 2020
4
I was wondering something, it says that my motherboard
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug*
  • 1 x Hyper M.2 Socket (M2_1), supports M Key type 2280 M.2 PCI Express module up to Gen4x4 (64 Gb/s) (with Matisse) or Gen3x4 (32 Gb/s) (with Renoir)**
  • 1 x M.2 Socket (M2_2), supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x2 (16 Gb/s)**
*M2_2 and SATA3_5_6 share lanes. If either one of them is in use, the other one will be disabled.
**Supports NVMe SSD as boot disks
Supports ASRock U.2 Kit
Does this mean that my motherboard can use nvme ssd or not? Because on the specifications i cant find any but it says supports nvme
"**Supports NVMe SSD as boot disks
Supports ASRock U.2 Kit",
Thanks in advance
Storage
Thanks in advance
I forgot to say, but my motherboard is Asrock B550M Pro 4
