Question ASRock H110 pro btc+ problem
6
Hello,
I currently have a problem with my Asrock h110 pro BTC+ motherboard
I bought 2 days ago this motherboard with a Corsair RM 1000X power supply, 8GB DDR4 RAM and an Intel Pentium Gold G5420 processor (3.8 GHz).
I mounted the motherboard as indicated on the manual provided, but when I press the power button on the motherboard, the ventirad turns on 1 second and then stops. no other noise and that's it.
There is no display on the screen I plugged in.
I then tried to change the position of the RAM, nothing.
I changed the RAM, nothing.
I changed the CMOS battery, nothing.
I unplugged everything and plugged it back in, nothing.
I put an M2 ssd with an OS, nothing.
I plugged in a graphics card, the GPU fans turn on for a second like the CPU and stop.
The power supply was used for my NAS server and it is functional for sure, I tried it after the tests on the motherboard and it works very well
I am out of solution. Does anyone have any idea how to fix my problem?
I thank you in advance for your help.
BeTa
Yeah it's totaly my bad, i thought the socket compatibility was enough to use with the motherboard. I didn't know this page.
But do you think the motherbord is dead cause of my fault?
Thank you
Little update before closing the topic.
I took the cpu compatible with the motherboard and everything is fine now.
After 2 months of testing , I had no hardware or software issues and my rig runs perfectly.
Reactions: rgd1101
