I push the power on button; all fans turned on (including the radiator fans), but the pump don't started. MOBO led (Dr. Debug) shows "15" for 3 seconds, then the pump started and Dr. Debug shows "22" and everything turned off.
I can hear a LITTLE "pip" sound when it cut off the power.
Then, it goes in a loop.
I have tried every Ram individually in every slot showing the same results.
I got the curiosity of trying without ANY Ram and it also showed the SAME results.
What can be the issue? Is the RAM, PSU, MOBO?
