ASrock z87 extreme4 + i5-4690k help
Youredonson666
6
So i just bought both of these items from microcenter, get home and install them and at first i was having the on and off problem, got that figured out, then i finally get it to boot up windows and I go to play a game and its stuttery as hell and I can't even play anything.
System specs are;
ASrock z87 extreme 4
HyperX Fury series 16gb DDR3 1866
Intel i5-4690k
Gigabyte G1 Gaming Geforce GTX 970
Cooler Master GX2 750W
I'm at a loss for this one. I updated the BIOS to the one that supports the i5-4690k and it still dose it.
Yes the GPU works perfectly fine.
Any help would be appreciated.
My temps on all 4 cores sit right around 108-111 degrees Fahrenheit with this webpage open, and ARK: Survival Evolved open. Without ARK it sits around 80-90.
I have a Hyper 212 on it, with 1 fan.
I don't see hyperX on there, but it still comes up on my computer that its there. Would that really be cause this many issues?
On my AMD board and processor before i would get roughly 50-60 fps on ARK and most games on ultra, now i can't even get 20 fps on ark.
sometimes non-validated memory can cause problems. i don't know if it's related to the gaming issue, but you should try running your pc with a kit that's on the QVL and check if you still have the same problems.
edit: can you try running your pc with a different psu?
Right now I'm going to try with some other ram thats on that list and see what that does.
I can't try with another psu because the one i had before this one isn't powerful enough 😛
is this new kit on the QVL? have you reset the bios after installing the new kit?
are your gfx card drivers up to date?
Yes, No, and yes.
