Question asus-bt 400 problem
Dec 18, 2020
11
asus-bt400 adapter doesn't work on my pc. I need to know how to remove the old drivers and install the new one.
I downloaded the drivers from asus and nothing works yet.
motherboard is a asrock b450 gaming-itx
Right-click on it in Device Manager and uninstall it there. Newer drivers should install over the older ones without issues though. Is the adapter detected as a device in Device Manager without any errors? Is it not installing or not showing up as a bluetooth device in Windows?
The dongle is not part of the motherboard. What exactly happens when you run the driver setup from ASUS?
I downloaded driver set up and run and everything installs but when I go to device manager it says
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
{Operation Failed}
The requested operation was unsuccessful
