Hi guys,
I've had an ASUS server RS926-E7/RS8 which I've managed for close to 7 years now (out of warranty). It's been great however a couple days ago the server shutdown on its own and now powers on but will not post.
Upon troubleshooting I found that the pins on the heat sink above the CPU had broken and popped off and the spring of the pin perhaps had created a short.
So I decided to take the 2nd CPU off and the server now posts just fine. I tested that CPU by itself and it works. So the issue is the 2nd CPU socket.
However, I'm now left with no being able to use the 2nd CPU socket and this is where I need help with identifying a component that most likely burned out.
Here is a picture of it: https://ibb.co/fQ7SdP4
As you can see in that image there is a component marked "R10A 1227" which looks discolored which I think is most likely dead, any idea what this component is?
Is that a resister or inductor or something else. Any insight into this is much appreciated.
