G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
How can I tell if I have an AT or ATX power supply?? Fan not working and I
need to replace it.
Thanks
"Doug" <doug57@www.com> wrote in message
news:u155U5nJFHA.1308@TK2MSFTNGP15.phx.gbl...
> need to replace it.
> Thanks
Unless it's a really old computer, it's ATX.
But just in case...the connector that goes to the motherboard is one piece
on an ATX power supply. With an AT power supply, that piece is two pieces.
Also, if you've got a name brand computer, you might have a non-standard
power supply, either size or connector. Make sure you get the right one, or
you could fry something.
>need to replace it.
>Thanks
AT type power supplies will have a heavy power cable (4 wires) leading
from the power supply to the main on/off switch on the front of the
computer case.
ATX type power supplies will have power connections to the disk drives
and motherboard, plus one for the front panel LEDs spliced onto a disk
drive power connector. The front panel on/off switch connects to the
motherboard with a two-wire connection.
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Be very careful when disassembling a power supply, as even when they are
turned off they can store enough charge to kill you.
I'd buy a new one
Neil
> need to replace it.
> Thanks
By the power switch. AT has an on/off switch and will lock into one position
or the other. ATX uses momentary contact. If it feels like a reset button,
then it's ATX.
Walter Clayton
Any technology distinguishable from magic is insufficiently advanced.
http://www.dts-l.org
> need to replace it.
> Thanks
Thanks for everything. I found it cheaper and easyer to replace the case
w/powersupply than to just replace the powersupply.
> need to replace it.
> Thanks
