ATC not working - help!!!
G
Guest
Guest
Archived from groups: alt.games.microsoft.flight-sim (More info?)
Hello All,
Recently I transfered MSFS from one machine to another using the method I've
seen suggested in this NG, a fresh install and then copy the directory
across.
Everything is fine except that some aircraft no longer have working ATC. I
can get the menu up for ground control, but I get no response from the key
presses.
Any ideas out there?
Thanks
Jon
Have you installed DirectX on the new machine? Google for where to get it.
....Carl Frisk
Anger is a brief madness.
- Horace, 20 B.C.
http://www.carlfrisk.com
"Jon Silk" <jon@silk.fsnet.co.uk> wrote in message news:d1rb2f$4gd$1@newsg2.svr.pol.co.uk...
> Hello All,
> across.
> presses.
> Thanks
> Jon
Carl,
The latest version of DirectX is on the machine. Also it's happening to
some aircraft and not others...
Regards
Jon
"Carl Frisk" <c.frisk@REMOVE.verizon.net> wrote in message
news:Feb0e.17991$UV2.14822@trnddc04...
> it.
> ...Carl Frisk
> - Horace, 20 B.C.
>> Hello All,
>> I've seen suggested in this NG, a fresh install and then copy the
>> directory across.
>> I can get the menu up for ground control, but I get no response from the
>> key presses.
>> Thanks
>> Jon
Do you hear other traffic? I not, could it be the avionics switch is off.
Sounds very basic, I know, but many TV repair guys have made house calls
only to find the plug out of the wall.
> Hello All,
I've
> across.
I
> presses.
> Thanks
> Jon
news:d1v025$rtv$1@newsg2.svr.pol.co.uk...
Date: Thu, 24 Mar 2005 18:14:45 -0000
Carl,
happening to some aircraft and not others...
Did you also copy your fs9.cfg file and others found at:
C:\Documents and Settings\{user name}\Application Data\Microsoft\FS9
And it might help to also copy over the Flight Simulator files from
you're my Documents folder as well.
Cheers!
___________________________________________
Bill (using a HP AMD 1.2GHZ & Windows 2000)
-- written and edited within Word 2000
