Question ATX power connector problem on HP Prodesk Motherboard ?
Mar 14, 2024
Hi. Recently, I bought an propietary motherboard of HP ProDesk 400 G4 Mid-Tower Business PC. But the problem is that the motherboard has 4-pin ATX Power Connector and My Power Supply has a 24-pin ATX Power Connector. Actually, I'm from Bangladesh and the default power supply is not available in our country. What's the solution of the matter? Can I use Converter instead of that power supply? Waiting for a proper answer. Thanks........
In the Motherboard :
CPU : Intel(tm) Core i3-7100, 3M Cache, Base Frequency : 3.9 GHz
RAM : SK Hynix (China) 4GB DDR4 2400MHz
It gets into such a spiral if you first don't have the full system and just not the motherboard. These current Hp newish/ used Pc's look like a great deal spec wise but are pitfalls.
Yes you could find that adapter to fit a normal power supply on that board but most OEM's will complain if is sees the front panel wiring missing meaning Hp's power switch, sound port and the USB ports.
Contact these guys but remember that solves the power supply issue not any hidden items moving forward.
Reactions: Fahim Sadmaan
