Here's a rundown of what I've tried
No sound plays through headphones when I plug into any of the aux jacks on my desktop PC. I am using the default HDAD driver. When I run a sound test in advanced properties of the digital audio device (set as default device) the level (green bar) spikes, but no amount of volume changing produces audio.
This may also be relevant
When I go into the list of playback devices this is what I find: when plugged into the rear jack the plug is detected under "Speakers" and available. When plugged into the front jack the plug is not detected at all. When the headphone is plugged directly into the monitor, It still doesn't work. I have tried this with 4 different headsets/earbuds. No combination produces sound
A big thank you if we can get it working and hopefully help others with similar issue
Specs
Windows 10 Pro 64 Bit (V1511 Build 10586.0)
AMD FX-6300
ASUS M5A99FX PRO R2.0
GeForce GTX 1060
Seagate ST2000DM001
- different headphones/earbuds make no difference. Sound works through bluetooth and monitor but never direct jack.
- tried front panel ports and all back panel ports.
- updated the audio driver, tested, then reinstalled the audio driver
- reverted to an older version of windows, tested, then reinstalled windows from factory
- checked the physical cables when the PC was powered down. Made sure all audio pins were in correct ports
Specs
AMD FX-6300
GeForce GTX 1060
Seagate ST2000DM001
