This is so annoying, basically for the past 3-4years I couldn't use usb headsets as my audio will be muddy / bassy and unnatural sounding, so when i had a 3.5mm headset i usded realtek hd audio manager to set the eq to powerful which makes all the audio sound normal like it is for most people, in the past 3-4 years i have upgraded my hdd to a ssd still had the issues upgraded my gpu multiple times, upgraded my pc case, motherboard , cpu and everything and now im on a new buiild with a new am4 ryzen motherboard new ram new cpu, but this time realtek hd audio manager doesn't open anymore for whatever reason, also i can't install it because of an error 0001 code, so once again i am stuck with muddy / bassy sound from my headphones, i use the hyperx cloud alphas, i've tried to run my headset through a mic amp with a adapter, same sound and i've googled everything every year for days, and i cant seem to find a solution, no disabling no enhancements doesn't work, yes i have tried many different headphones from usb to 3.5mm etc, only thing that fixes it is the eq from realtek which doesnt open anymore and i have tried other eq's they arern't as good, while it might be slight improvement , its either too high pitched or bad audio, while the realtek one was perfect, so if anyone got solutions for me or has the same issues, help me fix it thanks. im on windows 10 pro.
