Question Audio/sound problem with zebronics motherboard
Dec 1, 2024
5
Motherboard-H81M2
Iems- Tangzu Warner S'g Edition Black
Pc Specification-
CPU:i3 4150
CPU cooler: Intel stock cooler
Motherboard: Zebronics H81M2
Ram: Ant Esports 8 gb 1600mhz (dual ram total 16gb)
SSD/HDD: WD Green Sata Ssd 256gb
Hardrive-WD 500gb
GPU:Sadly the gpu died t400 4gb
Intel hd 4400 (current board graphics)
PSU:evga 450watt
Chassis: ant esports 120AG
OS: Windows 10 pro
Monitor: LG Ultragear 24inch 1080p 144 hz
Now the problem is that i use iems in the front audio jack the sound qualtiy is very bad and has no bass in it same goes for the back of the mobo.
I tried to install drivers from thw website but it did'nt work.
The iems are detected as Speakers in the system.
Please help me regarding this.
Pc Specification-
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Have you made sure the analog connector for the IEM's are fully seated into the connector on the rear audio output port on your motherboard?
Pc Specification-
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
please any other help??
Okay this might seem like Bs but while your playing music or have a game going slightly pull out the mini plug just a little.
Trust me I fight this every day as mini pins and there ports are slightly off. But when you pull them out just a little sound well sounds correct.
well you are kind of right i does not work on my pc but it might to others any other idea?
and thx for the reply.
