Hi guys, recently I have sent my motherboard to RMA but I need my new build for work (old i5 4690 is too weak for multiple VMs and docker containers), so I was wondering what I could think off these issues, since if I confirm it's a motherboard related problem I could buy a new one at a blink and ask for refund for the defective one (because oh boy it's definitely taking sometime). Here's my build:
USB Power Surge Warning on Windows - I did receive these warnings even if nothing was connected on the defective USB ports
I didn't know where it was, everything worked perfectly on USB 2.0 ports so I kept it like this while running MemTest86 at night (Passed with 4 tests and 0 errors).
After I wake up I tried to troubleshoot the issue with what I had at hand, turns out there's 4 USB ports that wouldn't work with more demanding USB devices (like a mechanical RGB keyboard) and kinda work with disconnections on less demanding ones, these are the USB ports with the issue:
A photo of the back of the motherboard with the USB ports that didn't work
Here's what happened when trying to plug stuff in these ports:
What I tried:
So, what you guys think, could this be a problem with the motherboard itself or it's anything else related problem?
Thanks for you time.
- Ryzen 9 3900X
- B550 Aorus Pro AC
- 32GB (2x16) 3200MHZ Corsair Vengeance RGB Pro (CMW32GX4M2C3200C16/Micron modules) - not in QVL list - (MemTest86 - 4 tests/0 erros) - Worked first time when I enabled XMP at Bios.
- GTX 970 Windforce
- Kingston A1000 M.2
- 1TB HDD 7200RPM
- 4 Corsair AF120 fans
- EVGA 750W Supernova
- Mechanical Keyboard - Didn't work at all (lights didn't even turned on)
- Wired Xbox 360 Controller from Feir - when I plugged in the lights would turn on and then turn off immediately, after 10 seconds would turn on again and turn off 2 seconds later, from there on a loop of connection/disconnection would start with the Windows sound effect going on in the background
- Phone charger - would work without disconnection but I sincerely don't know the speed it would charge.
What I tried:
- Disconnecting from the motherboard every front panel connections with the exception of power and leds
- Turning off XMP at bios (Remember the 0 erros from 4 tests in MemTest86)
- A new fresh install of Windows with internet off
- Reinstalling every USB driver from Windows
- Gigabyte Z97-D3H REV 1.1
- Intel Core i5 4690
- 16GB 1600mhz Team Group (not in QVL list)
- GTX 970 Windforce
- Kingston A100 M.2
- 1TB HDD 7200RPM
- 4 Corsair AF120 fans (actually it's from the new build but I kept it)
