Backup problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I'm trying to perform a full backup using NTBACKUP, and placing the backup on
an external hard drive. The backup won't run, and I get an error message
that says "The files for the recovery diskette could not be created. The
operation was aborted." I can't come up with any reason why this is
happening. Any ideas, suggestions?
What's the format of the external drive? FAT? NTFS?
Do you have write privilege to it?
"Sandy Human Rights" <Sandy Human Rights@discussions.microsoft.com> wrote in
message news😀F805DCA-0299-4FBC-B620-3F980686EFBF@microsoft.com...
> on
You are using the ASR function in backup. It creates the file, and then
expects you to furnish a floppy disk for it to put some recovery info on.
Perhaps you don't have a floppy, in which case you can't use this function.
That you don't have a floppy would explain your message.
Perhaps you have a floppy but did not insert a blank disk in the drive.
Ntbackup still cannot finish the task.
Jim
> I considered the absence of a floppy as a possible problem before I asked
> this question, and inserted one, trying again but getting the same result.
> In response to questions posed by another responder, I don't know if it's FAT
> or NTFS format, but I do have writing authority. This is a new Maxtor 80 GB
> external drive, just installed, but there is essentially zero documentation
> with it. More of a plug&play situation than anything else. But I'm getting
I assume you've installed it properly and formatted it?
Open My Computer, right click on the drive, Properties.
Is the file system RAW or NTFS?
> open (and how DO I tell whether the format is FAT or NTFA?). Thanks!
See above.
On Sun, 11 Sep 2005 12:14:01 -0700, Sandy Human Rights <Sandy Human
Sandy,
NT Backup is not exactly user friendly, there are a million things
have to be correct to run a backup and even then you can end up with a
useless backup that cannot be restored unless you know exactly what
you are doing.
My advice is forget NT Backup and get yourself a copy of Norton Ghost
or Acronis True Image and write a drive image to your external HDD.
Acronis in particular is nigh on bullet proof and very easy to use.
Save yourself the grief.
Jonah
> you are doing.
Useless in what way?
Because of user error during the setup/backup (not checking System State
or the right directories, for example?), or because of a bug in Backup?
