I just recently finished a new built, and am having a bit of a problem which I believe may be due to a bad cpu. When I push the power button, the fans will spin for a moment and immediately stop and you can hear the PSU 'click' as it begins and immediately stops sending power to the MB. I must pull power from the wall or reset cmos before the power button becomes responsive again. Everything will power on and run fine, but only if I've pulled powe from the CPU itself; as soon as I plug in the 12V CPU power the problem begins to repeat itself.
Upon finishing assembling the components and powering up for the first time, everything powered up then after about 3-5 seconds shut itself down, 3-5 seconds after that the machine restarted itself. This happened two or three times before restarting and continuing to run.
Once it stopped restarting itself and continued running, the monitor received signal, displaying the motherboard logo and bios screen which said "new CPU installed, press f1 to enter setup. I left it for the time being to wrap up some other things before finishing. I came back about 5-10 minutes later and as I was walking back to the machine it shut down again and has not been able to restart since.
I removed everything from the motherboard except only what was needed to run and the problem remained. I've reset the cmos, pulled the battery overnight, replaced the aftermarket cooler with the stock one. After resetting cmos or unplugging the power supply from the wall for a few minutes and plugging back in, the machine will try to restart but with the same results.
I'm guessing this is a bad CPU but I'm confused and concerned. Why would it seem to work at first and then stop? It appears that the CPU wasn't DOA which causes me to wonder what else could have caused the CPU to fail. That concerns me because if I get a replacement, what if some underlying problem causes that one to fail, too?
I really appreciate any feedback or suggestions anyone might have to share with me.
Asus P8-Z68 Pro V3
i7-2600k
OCZ 160gb Vertex 3 SSD
OCZ 850W
16gb DDR3 1600
Asus P8-Z68 Pro V3
i7-2600k
OCZ 850W
16gb DDR3 1600
