G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.video (More info?)
Hey guys,
I plan on making the step from my budget Wal-Mart KDS X-Flat 17" CRT to
a semi highend 19" LCD-- and was toying with two displays I found on Newegg.
Firstly, here are the links:
http://www.newegg.com/Product/Product.asp?Item=N82E16824174024
http://www.newegg.com/Product/Product.asp?Item=N82E16824163129
They look to be the same monitor to me... same price, same size. Only
thing is, I noticed that the Neovo has '12ms' over AOpen's '16ms'. I'm
not quite sure what this means.. is bigger better, or is it like pings
in games.. you want to get the lowest possible?
I plan on doing gaming on this monitor. The Neovo looks more tempting as
it lacks the useless speakers the AOpen has, and has had good reader
reviews that cited the monitor was good with games like Doom 3, HL2, Far
Cry, etc.- The kind of games I'm into.
Anyone care to share the knowledge? Thanks for any input.
Cory "Shinnokxz" Hansen - http://www.coryhansen.com
Life is journey, not a destination. So stop running.
Hey guys,
