Question BCD corrupted, cannot repair in Advanced Recovery Mode ?
Page 11 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Kyroix 74
205
Hi, i recently did a Windows quality update and i got several pop ups after a reboot saying ‘We couldn’t complete the updates, undoing changes’. This kept coming up. But one time i booted up my pc and it did not start up, instead giving me the screen to the advanced repair mode. I did all the options in the troubleshoot section, nothing worked. I did the command prompt, and ran a couple commands including BCD. It appears my BCD is corrupted. So i did the BCD repair commands, but they didn’t work. So i was stuck.
I clicked "Continue to Windows", but didn’t go back to the same screen, instead the horrible ‘Your device/pc needs to be repaired’. And the 4 options to boot on the advanced recovery, BIOS, and 2 others i forgot. I tried pressing F1 which was the allocated button for booting into the Advanced recovery again, but it didn’t work instead yakking me back to the same screen.
So currently i am stuck on the repair screen, not able to do anything on it except use the button to go into BIOS, but i don’t think i can do anything in that to get into Windows. So i think, 99% my BCD being corrupted is what caused my Windows to not boot up. I need some help because Resetting the PC is my last resort. I hope this massive oarsgraph makes sense to you.
Those are old windows files.
If you forgot to backup some of your user files, you can still find them there.
If you don't need them, then just delete windows.old folder. But be absolutely sure, that you don't need them before deleting.
And no - you can not copy program files from there. That will not work.
You have to reinstall all your apps.
Ok. That’s fine.
Oh yeh i know what it is but what do i take a pic of
Screenshot of Disk Management.
It looks similar to this:
Oh, thought i did. Well, what should i do then, is it bad? Do i need to delete them? Also i wanna know how to make that 100GB unallocated space be put back into my C drive
Since this is a brand new install, you'd lose nothing by doing it all over again.
In the above linked tutorial, look at Section II, Step 6 & 7.
That speaks to DELETING all existing partitions, and continuing with a completely blank drive.
Read that tutorial thoroughly.
Then read it again, and internalize all the steps.
Do what it says.
Reactions: Kyroix 74
Also a question, all the files from the windows.old folder, can i just paste into my new windows? What do i do with all the files in there. It includes my program files and everything.
Don't copy everything. Just copy the files you need from Program files folders. The directX and visual C++ need to be reinstalled all over and the drivers. You can only copy your personal apps from there like chrome
