hello everyone,
i have a problem with my system:
MB: asus rog x870e hero
cpu: amd 9800x3d
aio: asus rog ryujin iii extreme
fans on aio radiator: x3 a12-25 pwm noctua (top exit)
rear fan: a14 pwm noctua (rear exit)
front fans: supplied with hyperior case (front entry)
I can't read the fan speed on front fans, also I'm not sure if I connected everything in the right place
connections:
- pump: aio_pump
- front fans: fan 2, fan 3, fan 4 on hyperior supplied hub
- rear fan: cha_fan4 on motherboard
- fans on radiator: cpu_fan, through a 3-1 splitter (4-pin male, one 4-pin female and the other two 3 PIN)
the hub (mb pwm) is connected to the mb (cha_fan1)
in fact in the bios I am able to view/set everything, but:
-fans on radiator on cpu_fan
-rear fan on cha_fan4
-pump on aio_pump
- the front fans are working and I can adjust the speed, but the speed is not read (Fan speed N/A)
P.s the aio screen always shows 10 degrees less than hwmonitor
What would be the right wiring?
Thanks
cpu: amd 9800x3d
connections:
- pump: aio_pump
-pump on aio_pump
Thanks
