Best IDE card for a PowerEdge 2300 ?
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
The original SCSI CD-Rom in my pe2300 is dying; I'm getting more frequent
read errors. I want to replace it with a CD-RW anyway, but these are almost
impossible to find in SCSI with a black face. I'll probably go with IDE
which means adding an IDE card to the pe2300.
I've tried two IDE cards, a SIIG SC-PE4A12 UATA-100 and a no-name ATA-66,
both hang the machine at POST. (The SIIG is an odd card anyway, it also
hangs an IBM, so I wasn't too surprised)
Anybody know of an IDE card that is KNOWN to work in a pe2300 ?
I don't really need the latest UATA-133, it's only for CD-Rom access.
- FM -
if you ever want to boot from the CDROM again, DO NOT put an IDE Card in
there.
If the color is that much of a big deal to you, just remove the faceplate
and paint it.
Or, look here:
http://search.ebay.com/dell-SCSI-CDROM-poweredge_W0QQsojsZ1QQfromZR40
- NuTs
"Fred Mau" <fred-dot-mau@comcast.net> wrote in message
news:Xns962352904D910freddotmaucomcastnet@216.196.97.131...
> almost
> - FM -
"NuTCrAcKeR" <nutcracker@internationalhacker.org> wrote in
news:Lf-dnWPZ8KxkVN7fRVn-hg@speakeasy.net:
> in there.
> faceplate and paint it.
> Or, look here:
> - NuTs
Had to give up on the IDE anyway, tried several cards (Promise, SIIG, etc,)
couldn't find ANY that wouldn't hang it at POST. Must be something about
the motherboard, I even pulled every other card and turned off everything I
could find in the setup, still hung.
I ended up sticking in a beige Ricoh SCSI CD-RW (for now).
The problem isn't finding a black SCSI CD-ROM, it's finding a black SCSI
CD-RW.
- FM -
news:Xns9624522E71F98freddotmaucomcastnet@216.196.97.131...
>> in there.
>> Or, look here:
>> - NuTs
> etc,)
> I
> CD-RW.
> - FM -
Its a SERVER ...
get over it, or paint it !
End of story !
you dont have other options !
