Best Intel Core 2 Duo and Core 2 Extreme for Photography Editing
Kairukun88
Hi there,
I was just wondering if someone could recommend what Core 2 Duo processor works best with photo editing and some light video editing. I'm building a PC for someone as a gift that does a lot of that and was curious as to which processor would be best. I know that the new quad core processors are ideal, but like most, I have to remain on a budget and would like the best that I could get for my money and specifically editing.
Thank you!
You'd get more bang for your buck from a slightly overclocked i7 920 than downing $1000 dollars into an outdated core 2 extreme processor.
What specific software?
doesn't editing benefit from multiple cores? that I'd surely go for Quad core... maybe Phenom 2 810 oder Intel core2q 8200?
It will benefit more if you get a E8400 and spend your money on a SSD drive. Most of the time the bottleneck, after your E8400, will be the storage.
What software are you using? This may dictate whether a Quad be better than a Duo
Phenom 720BE / Asus 790GX AM3: $210 AR
Quite similar to the e8400 in PS performance. The extra core of the 720BE will provide a boost in the "light video editing". The Phenom 810 would be a great overall deal (if it restocks in the next few days) if the user utilizes plugins or filters that will run across 4 cores.
With the extra $$$ saved buy a second HD for a scratch/capture drive, or maybe 2 extra Gb of RAMs.
If you already have your s775 mobo go for the e8400.
