best matrox card for dvd and projector?
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.matrox (More info?)
Hi,
i own since years an old Matrox G400 DH for
computing and now i tested the dvdmax function
to watch dvd and tv on video-projector.
i saw there a few new matrox products
out there. is there any new card that can beat
the image quality on TV / Projector or i´m
still ok with the old g400?!
i´m not a gamer, i´m just searching for a
new videocard with the best possible image
quality for dvd!
G
Guest
Guest
lars eidberg wrote:
> Hi,
> quality for dvd!
How is your projector connected? S-Video, DVI, Component, VGA, what?
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
G
Guest
Guest
> > quality for dvd!
connected with VGA..
DVI would be great but my projector hasnt
G
Guest
Guest
>> > quality for dvd!
I don't think you're going to see any difference between your G400 and a
newer board. You'd do better to look into your software. Right now the
hot setup seems to be TheaterTek, <http://www.theatertek.com/> but hold off
a bit as version 2.0 is about to ship.
Another option that some hardcore videophiles have done is go to a hardware
MPEG-2 decoder and a PDI interface played back through dscaler--for details
see
<http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=267735&perpage=20&pagenumber=1>.
Not simple to set up but supposed to work about as well as a high-end
standalone DVD player.
--John
