[SOLVED] best motherboard for 2990wx and can fit two RTX 2080Ti using Nvlink without suffocating one of them
Ammar Ammory
12
HI everybody
what do u think the best motherboard for Amd 2990wx and 128 gb of rams
in my opinion and after spending all the weekend searching online it seems ( ASUS ROG Zenith Extreme Alpha X399 ) is the best choice
and regarding video card it seems i have 4 options :
-MSI LIGHTNING-Z RTX2080 TI
-MSi SEA-HAWK-X RTX2080 TI
-EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID
-And finally ASUS ROG-MATRIX-RTX2080TI but i don't know when it will be released
i read some problems about evga cards regarding the noisy pumps . so i will not consider it
so the question here are my choices right or not ?
and what is the best motherboard and dual video cards to connect with
NVLink without suffocating one the other
and thanks in advance
Matrix just released maybe one week ago? Just went to the internet, seems like people are having problems with other x399 motherboards such as nvlink isn't working. I guess you could go with this board. The lightning z requires three 8 pin connectors so if your power supply can support it then get it otherwise i would get the sea hawk x.
Reactions: Ammar Ammory
-Motherboard - Asus ROG ZENITH EXTREME Alpha
-CPU - AMD Ryzen Threadripper 2990WX
-VGA - MSI LIGHTNING-Z RTX2080 TI * 2
-RAMs - 2*HyperX Predator DDR4 RGB 64GB Kit (4 x 16GB) 3200MHz / Total 128GB
-SSD - Samsung 970 PRO 512GB
-HDD - WD 4TB Gold HDD * 2
-Case - Cooler Master Cosmos C700P E-ATX Full-Tower
-Cooler - Cooler Master Wraith Ripper
-PSU - ???
-PSU - ???
your psu should be fine.
