[SOLVED] Best value build for a 1400p RTX 3080 build?
alexbeast
157
I finally picked up my Aorus RTX 3080 master from a local computer shop and now I'm puzzled about what I should pick for the rest of the build. I want to run 1440p max settings for years to come but I also don't really care about aesthetics that much. In terms of CPUs im pretty torn between 5900x and 5800x so if anyone would have recommendations for a build, I would appreciate it. My budget is about 3000-3500 CAD (2400-2800 USD). Also this build will be for strictly gaming and possibly streaming.
Here's another option worth considering. This set up allows you to run that cpu with the power limits turned off in the bios. It's a round a bout way of OC those cpu's .. it keeps them in turbo boost mode longer.
https://www.canadacomputers.com/product_info.php?cPath=6_1937&item_id=175084
Lian-Li LANCOOL II Mesh Performance Case $139.99
https://www.memoryexpress.com/Products/MX71371
Seasonic Focus Plus Gold 850 Modular Power Supply $179.99
https://www.memoryexpress.com/Products/MX00115631
MSI MAG B560M BAZOOKA $179.99
https://www.canadacomputers.com/product_info.php?cPath=4_65_1971&item_id=190143
Intel Core i7-11700F $419.00...
https://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=137819
be quiet! DARK ROCK 4 CPU Air Cooler $99.99
https://www.canadacomputers.com/product_info.php?cPath=24_311_1326&item_id=175092
Kingston HyperX Fury Black Series32GB (2x16GB) DDR4 3200MHz CL16 $199.00
https://www.canadacomputers.com/product_info.php?cPath=179_1927_1930&item_id=185539
WD Blue SN550 2TB M.2 NVMe SSD $294.00
Total: $1512 CAD
https://www.canadacomputers.com/product_info.php?cPath=22_700_1104&item_id=140135
ASUS TUF Gaming VG27AQ 27” G-SYNC Monitor ELMB Sync 1ms 165Hz WQHD 1440p IPS HDR Eye Care with DP HDMI $529.99
A better look at that board.
https://www.msi.com/Motherboard/MAG-B560M-BAZOOKA
A better look at that case.
