[SOLVED] Best way to configure fans
TraineeIdiot
Commendable
Apr 7, 2020
31
I have:
NZXT H710i case, comes with 4 NZXT fans - cam hub
3x Corsair LL120 - got two hubs in the box, one much larger than the other
and my MOBO is the Crosshair VIII Hero.
What is the best way to configure all of these?
Is there one software I could use to control the speed and then just Corsair for the rgb. If so, that is fine but I am unsure the best way physically configure this what cables go where. What hub is straight to the MOBO ect.
Do I need to get extra cables/daisy chains and so on.
Thank you kindly for you repsonses.
Bring air in from the front of the case and exhaust it out the rear and top compartments. That is the most optimal air flow for the case.
As for controlling RGB software, you have to use the manufacturer's software. There isn't a "control-all" tool.
