Best way to set fans up in NZXT S340?
KieranPCGamer
531
Alright Guys,
Need a little help witch is the best way to set my fans up,
i will have a 1x 140 in the back 1x 140 at the top and 2x 140
on my Corsair 110i GTX Rad, also what the best Fan Hub to buy?
You're best off using the TOP 140mm fan as an intake, and the BACK fan as an exhaust. [strike]For the controller, anything that fits your case and needs will do, https://pcpartpicker.com/part/nzxt-fan-controller-senmix2[/strike]
EDIT: The S340 doesn't have room for a 5.25 inch controller, but it comes with its own fan controller. Don't know if it's with software or some switch on the back, but you should be fine.
