Whenever I turn on or restart my PC I am always met with the same screen/message and it always resets the BIOS settings. If I change the settings, F10 to save, then go past that raid configuration pop up screen again and press f8 to bring up bootable drives and boot into my windows drive then I can use windows with the changed settings. After shutdown or restart I have to rinse and repeat.
There is also a small chance maybe 5% that when I boot it doesn't find a bootable drive at all when I power up. This is always fixed with a restart or 2. I have replaced CMOS battery and flashed the bios to try and solve.
Screen 1
Screen 2
After I changed the settings, went to F10 to save and restart I get the first screen again but the settings stay (Memory set to 3200).
I press F8 to bring up the bootable drives and boot straight into windows from that screen. Any other way brings me back to screen 1 and resets the settings.
Also I should mention that once I am in windows it runs fine. No crashes or under performance or anything of the sort.
Any help is appreciated. Thanks
Screen 1
Screen 2
