Black and gold build need help finding case please.
JamyPatch44
56
Ok so these are the parts that i eventually came up with, I got most of these images from goggle as i just wanted to show you what colour scheme i was trying to aim for but i need help finding a case please any help will be appreciated.
MOBO: Asrock z77 extreme 4
CPU I5 3570k
GPU: Palit Jetstream GTX670
HDD: 3TB Seagate 7200rpm
RAM: 8Gb corsair vengance black
PSU: Corsair TX 750w
DVD Burner: Lite-on iHas124b
Case: ???????
Watercooling: Custom watercooling loop with gold fluid colour
Led's: ???????
And then i have gone for a blue theme for the peripherals
Keyboard: Roccat Isku
Mouse: Roccat Kova +
Mousepad: Roccat Alumic
Monitor: 1920x1080, 21.5 inch acer < The power button is blue
headset: Turtlebeach x12 < Green and black :X
Ok, first off, that gold fluid is not designed for longterm use in a loop, its predominantly used for showcases at tradeshows,
But I like the colour scheme and to get the full effect here you are going to have to up your game, a lot
Hard drive, paint the steel cover black
Optical drives paint the internal surfaces black
Northbridge/Southbridge and I/o sockets gold
Remove the labelling from the Psu
Whichever blocks you use for the loop should be gold/black
are you W/c'ing just the Cpu? as those cards wouls fit the colour scheme I'm assuming you are keeping them as is, or modding them to have W/c whilst keeping the shrouds?
And the case you choose, black as night, big, no leds, maybe white cathodes to bring up the shine on gold parts/paint
but I see a lot of paintwork on this one, highlighting Psu/drives/blocks etc,
and it absolutely cannot look half-arsed in any way,
are you up to it?
You will also be modifying the case somewhat, just to forewarn you 😛
So check out the large fulltowers with black internals, removable hard drive cages are nice, but not essential as you can remove 'non-removable' ones anyway
I would suggest a clean looking case such as this,
http://www.bing.com/images/search?q=black+fulltower&view=detail&id=07A6EB7A16DB30115BC342B6E964A44C4FB2D041&first=0&FORM=IDFRIR
Moto
Ok do you think blue liquid cooling would look nice in this build?
Which paint would i use to paint the HDD,Drives and north and south bridge?
Removing the label must be easy
Ok gold and black plates?
Im just going to OC the CPU
Ok so i have just seen this case and i think this may do the job > http://www.scan.co.uk/products/nzxt-phantom-410-black-performance-mid-tower-case-with-2x120mm-and-1x140mm-fans-usb-30-w-o-psu
and i will add some white cathodes to the inside of my case
which parts to highlight on the PSU etc?
Yes i am up to it.
Edit i have just seen your edit i will look for a different case.
As it will not let me edit my reply i will have to do another post
Ok so i have just seen this case and i think this may do the job > http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-BX&campaign=pcm/googleshopping and then replace the badge with a gold version instead http://ncix.com/products/?sku=71191 and then replace the side panel for a bigger window http://www.ncix.ca/products/?sku=66820
Yes i am up to it.
Ok thanks for the help :)
