I just changed the title as the situation changed once I made this post.
Here's my current rig
Motherboard: Asus H81M-CS
Processor: i5-4440 3.1Ghz
Ram: Kingston hyperx fb-dimm (4GB)
SSD: Kingston SSDNow 300 (128GB)
HDD: WD 1TB
Graphics Card: GTX 750Ti
PSU: Antec VP450P
So, a bit of context first,
I had some issues with my motherboard earlier and got it replaced. They claim it was a brand new one, but I feel it was refurbished. I had a few issues at that time (kept getting a CPU over voltage issue). I'm not sure if the issue was resolved by a BIOS update or a new PSU, but it has been working fine since then. Here is the link to the post I made here at that time.
I used to keep the desktop case on a table next to the monitor earlier, however, as that was not very comfortable I recently got a computer table (atleast that's what it's called here where I live). It's basically a table with a retractable shelf for the keyboard and mouse and a closed storage for the desktop case. The carpenter who made it had first assured my that he would try and add a "net" on one of the sides so the system would get some air and cool. However, what was delivered was quite different. It was a completely closed space with no space even for wires to go out smoothly. It was a bit too small too. It could basically fit the computer case but not the wires once connected to the backside (D-Sub, power, keyboard and mouse etc). I got a few holes drilled at the back so the wires could come out, however, I don't think they were enough for any ventilation. Especially for the PSU as the fan faced a closed space. While drilling the holes, the carpenter asked me to place the computer case in and out a couple of times to check if the holes were drilled in place.
Once all was done, I connected the system and tried to boot. It did not. The system would just power up for a second then then die out to make an attempt again. So it would basically just boot for a second, shut down, reboot again for a second. This would continue until I cut the power source. At that time I had two probable causes in mind.
However, today the system suddenly shut down and the problem has returned again. Just before the shut down I had a few chrome tabs open and maybe an excel sheet and illustrator. I first removed the cleaned the GPU, however, this time it did not help.
After this, I tried the following things
So my question is
I was suspecting the MoBo was bad, however, when I tried removing the RAM and booting without memory, it gave a series of long and short beeps. I see this as a sign that the MoBo might be fine, I'm really confused now.
HDD: WD 1TB
PSU: Antec VP450P
- Something (mostly the GPU) may have shaken from all the movement, connection and reconnection of the case while drilling the holes
- The saw dust from drilling holes into the wooden table may have entered the case
- Heat build up
- Removed component after component starting with the GPU followed by the keyboard and then mouse.
- Changed the RAM slot
- Replaced the PSU with a spare one
- Plugged into the wall instead of the UPS
- Tried a different power cord
- Motherboard
- Processor
- Some damage done due to heat build up.
So my question is
- Is there a way I can further check for what the problem could be without changing the motherboard or processor.
- Could the problem be something else that I am missing.
