Question Blue Screen issue when enabling X.M.P
srijon_ashraf
Commendable
Nov 3, 2022
Using Gigabyte AORUS 8*4 = 32GB 3200MHz RAM. When I enable X.M.P profile, I get a blue screen with the error code 0xc0000221/0xc0000428. It works fine when using just 2 RAM but gets errors when using 3/4 RAM. What to do now?
MB: Gigabyte B450M AORUS Elite.
CPU: Ryzen 5 3600.
RAM: Gigabyte AORUS 8*4 = 32GB 3200MHz
PSU: Corsair CV 550 Watt 80 Plus Bronze Certified PSU
What BIOS version are you on for your motherboard? Also, have you tried manually inputting the timings, frequency and voltage into BIOS manually? Your specs are incomplete, you're missing the discrete GPU's make and model.
What BIOS version are you on for your motherboard? Also, have you tried manually inputting the timings, frequency, and voltage into BIOS manually? Your specs are incomplete, you're missing the discrete GPU's make and model.
Bios Version: F64
GPU: Asus Phoenix GeForce GTX 1650 4GB DDR5.
I tried to input the values manually but the fact is there is no option to increase the voltage to 1.35V. It will only be possible if I enable the X.M.P, enabling XMP trigger the Voltage to 1.35V automatically.
