Question Blurry and lower res. screen when extending and using multiple monitors - RX 580
Dec 16, 2022
Hi
I have a 1440p , 165Hz monitor connected via a DP cable. When only using this monitor, I get the full res. and refresh rate.
But when connecting a 1080, 60Hz TV (or any other 1080 monitors, connected using either HDMI cable or HDMI to DP converter) , I get blurry screen on my main (the 1440p), unless I lower its refresh rate to 60Hz.
Furthermore, if i leave it at anything above 60 (120, 144, 165) in the windows settings it says:
Desktop mode: 2560 x 1440p, 165 Hz
"Active signal mode: 1920 x 1080p, 165 Hz"
My CPU does not come with iGPU, so I can't connect the second monitor via MB.
Have tested the GPU Scaling, turning off FreeSync, reinstalling and updating the driver, etc. Only lowering the refresh rate works.
Any suggestion how I can connect more monitors and get the full refresh rate on my main?
Dec 16, 2022
Hi
Somewhat solved the problem...
By turning off the FreeSync, that problem is solved.
But now I cannot activate HDR as long as I'm extending my main monitor!
LG UltraGear 32GN650-B
