BSOD System_Service_Exception and Kmode_Exception_Not_Handled and Interrupt_Exception_Not_Handled
Oct 1, 2018
I recently upgraded my Ryzen 5 1500x to a 2600x and changed my 8 GBs of memory to 16. I got the Flare X memory because it said it was for Ryzen. Now every few minutes it crashes. I believe I've updated all of my drivers and reinstalled windows 10 nothing has worked. Please help
System specs
Cpu: Ryzen 5 2600x
Memory: 16GB G.skill Flare x
Motherboard: Gigabyte AB350 Gaming with bios 23
Graphics: Zotac Gtx 1080 mini
Minidumps:
http://www.mediafire.com/file/ico1io8mq78ydz9/100118-6687-01.dmp
http://www.mediafire.com/file/5sxczq8be7bs04o/100118-7359-01.dmp
http://www.mediafire.com/file/4ti70nyh18rk2ia/100118-7609-01.dmp
http://www.mediafire.com/file/k06o4d468689d87/100118-6703-01.dmp
http://www.mediafire.com/file/d23yg12tuawid4g/100118-6593-01.dmp/file
Answer: when I put the ram in single channel it runs fine. In dual channel it causes multiple BSODs.
Did you use the App center to update drivers?
https://www.gigabyte.com/us/Motherboard/GA-AB350-Gaming-rev-1x#support-dl-utility
Have you run memtest86 on your ram sticks? 1 memory stick at a time, up to 8 passes. Only error count you want is 0, any higher means a bad stick.
Did you buy a set of 2x 8gb to replace 8gb or just add another stick? I believe individual sticks, even if same family, may not get along together. Tried running them in single channel?
Hi, I ran the dump files through the debugger and got the following information: https://pste.eu/p/HXqk.html
File: 100118-7609-01.dmp (Oct 1 2018 - 10:52:11)
BugCheck: [INTERRUPT_EXCEPTION_NOT_HANDLED (3D)]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
Probably caused by: nvlddmkm.sys (Process: System)
Uptime: 0 Day(s), 0 Hour(s), 09 Min(s), and 53 Sec(s)
File: 100118-7359-01.dmp (Oct 1 2018 - 10:13:00)
BugCheck: [KMODE_EXCEPTION_NOT_HANDLED (1E)]
Probably caused by: ntkrnlmp.exe (Process: System)
Uptime: 0 Day(s), 0 Hour(s), 05 Min(s), and 32 Sec(s)
File: 100118-6703-01.dmp (Oct 1 2018 - 10:15:09)
BugCheck: [SYSTEM_SERVICE_EXCEPTION (3B)]
Probably caused by: win32kfull.sys (Process: csrss.exe)
Uptime: 0 Day(s), 0 Hour(s), 01 Min(s), and 41 Sec(s)
File: 100118-6687-01.dmp (Oct 1 2018 - 10:07:02)
Probably caused by: memory_corruption (Process: dwm.exe)
Uptime: 0 Day(s), 0 Hour(s), 01 Min(s), and 10 Sec(s)
File: 100118-6593-01.dmp (Oct 1 2018 - 10:39:34)
Probably caused by: memory_corruption (Process: Taskmgr.exe)
Uptime: 0 Day(s), 0 Hour(s), 03 Min(s), and 53 Sec(s)
One of the crashes was caused by the NVIDIA graphics card driver nvlddmkm.sys. There are a few things you can do to fix this problem.
#1. Try a full uninstall using DDU in Safe Mode then re-install the driver. [More Information]
#2. Try getting the latest version of the driver, or one of the 3 most recent drivers. http://www.nvidia.com/
#3. Allow Windows Update to download the driver for you, which might be a older/better version.
This may not fix your BSOD problems but might reduce the number of BSODs you are getting.
I just updated through app center and the only driver that wasn't up to date was the LAN driver I had. I have also run memtest86 and it passes with no errors. I'm going to run it longer to check but it seems fine. The set of ram I bought is a 2x8gb set. I still get the same crashes.
