[SOLVED] Build constructive criticism and help
UKTone
153
6
18,695
PCPartPicker Part List
CPU: Intel Core i7-13700K 3.4 GHz 16-Core Processor ($421.99 @ Best Buy)
CPU Cooler: NZXT Kraken X53 73.11 CFM Liquid CPU Cooler ($122.99 @ Best Buy)
Memory: ADATA XPG LANCER RGB 32 GB (2 x 16 GB) DDR5-6000 CL40 Memory ($329.99 @ Best Buy)
Storage: Samsung 980 Pro 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($79.99 @ Best Buy)
Video Card: MSI GAMING X TRIO GeForce RTX 4070 Ti 12 GB Video Card
Power Supply: Thermaltake Toughpower TF1 - TT Premium 1550 W 80+ Titanium Certified Fully Modular ATX Power Supply ($499.99 @ Best Buy)
Operating System: Microsoft Windows 11 Pro OEM - DVD 64-bit ($159.99 @ Best Buy)
Total: $1614.94
Generated by PCPartPicker 2023-01-16 18:15 EST-0500
total cost would probably be around 4000 (including the monitor, a second ssd, another aio for gpu, 4070ti)... which i can afford but, am having second thoughts.
https://www.bestbuy.com/site/asus-r...th-hdr-displayportusb/6515267.p?skuId=6515267
Building a computer has become so hard for me now, think it's mainly because i don't know enough about motherboards, aio coolers, pcpartpicker doesn't have enough filters to make the choices easier, if i really need an i9 or i7 k or if i should try things out, and if i'm bottlenecked, then upgrade, i don't know enough about productivity programs, etc. And i am also not sure how much i'll need to change once i learn more.
Also, how do i find an aio for a gpu?
Why is this so hard lol. I want to stream at 4k, video edit, learn 3d animation, learn adobe, etc. Is $4000 worth it? Or should i lower my rig's costs? If so where?
Total: $1614.94
I'm not seeing a case nor motherboard in that build.
Reactions: UKTone
The motherboard best buy doesn't have Z790/z690 ddr5 motherboards and i wasn't sure on what case to get.
Yeah it is pricey, think i was getting way ahead of myself, need to slow down. @gmikkonen
@Why_Me Yeah think i will just go with most of what you're suggesting (if they have it at best buy or microcenter), i may even wait on upgrading my gpu. Thank you for all the help with all the other suggestions too.
Reactions: Why_Me
