Haha I'm sorry rugger, I just got off required nap 😛 The budget is probably around 1100, which may not even be necessary. I'm building this for higher-end gaming performance, not highest, and I do want to do some overclocking on this. I'm also trying not to build this into a dead end, unlike my S478 here...
Processor: AMD Athlon 64 3000+ Venice <b>$146</b>
Motherboard: DFI Lanparty UT nF4 <b>$129</b>
Video card: BFG Tech 6800GT PCIe <b>$349</b>
Memory: OCZ Gold Series (2x512) PC3200 <b>$138.75</b>
Power supply: Fortron 550-60PLN 550W <b>$96</b>
Case: Lian-Li PC-61 <b>$110</b>
<b>Total: $968.75</b>
As for case I'm pretty close to certain on what I want, but I will look at any suggest aluminum cases. Preferably plain because I want to mod it.
Now here are some questions that I have for you guys.
1. Do I go with the lesser video card and OC it up to Ultra performance, or fork the cash over and get the 7800?
2. The board I listed has 2 PCIe slots but is not SLI. Am I better going with an SLI capable board for the future? I know DFI has a very similar SLI board out there, or do I go with another brand? Also most the reason I chose DFI was for the available voltage for the ram I picked.
3. Stay with OCZ or change it to a less demanding type or switch brands altogether. Mainly just need the ram to keep up with the OC.
4. Power supplies are definitely a weak area for me, for all I know that one is POS. But I did try and research.
Thank you in advance.
