AMD Ryzen™ 2nd Generation/ Ryzen™ 1st Generation Processors : *2
1 x M.2 Socket 3, , with M key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 x 4 mode)*3
1 x M.2 Socket 3, , with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)*4
2 x SATA 6Gb/s port(s)
AMD Ryzen™ with Radeon™ Vega Graphics Processor : *2
1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 x 4 mode)*3
AMD B450 chipset :
4 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
*3 When the M.2_1 Socket 3 is operating in SATA or PCIE mode, SATA6G_5/6 ports will be disabled.
*4 When the M.2_2 is occupied by M.2 device, PCIe x16_1 will run...
MSI is not better than ASUS and ASUS is not better than MSI. It completely depends on the specific board. However the MSI i linked is an excellent board. You can always go cheaper as I stated above, just giving you one I know to be very good. You can always go cheaper.Why you say that cheap and bad . You dont believe asus products? Is msi 450 beter than asus 450 f gaming ?
Both of the PSUs that myself and @helper800 have suggested are both excellent. I would opt for the Seasonic, however I suggested the TXM as it's still excellent and was on a particularly good deal.Hi. This is my list Cpu;r5 2600x. Gpu; rx 580 or590. Ram;16g corsair 3000mgz. Board;b450 f gaming asus. 1T hdd and 512 ssd case fan;6 and 1 dvd writer is good? And ram,cpu is match? Please suggest me a good psu. 😊
Also agree this is a fine budget board, as long as you're not looking at higher levels of overclockingAsrock b450m pro4 is $70, I've built 18 systems with this motherboard and not a single one has given a problem it's literally the cheapest b450 you get buy that isnt junk.
I actually read what he said wrong lol, he said "suggest me chipset b450 motherboards" I thought he said cheapest instead of chipset.Also agree this is a fine budget board, as long as you're not looking at higher levels of overclocking![]()
what do u mean?Asrock b450m pro4 is $70, I've built 18 systems with this motherboard and not a single one has given a problem it's literally the cheapest b450 you get buy that isnt junk.
Yes the asus b450 gaming f is great and so is the msi motherboard they recommended, I was just showing u a good cheaper board if u wanted to save moneywhat do u mean?
asus f gaming not good?
that is a high end b450 broad 🙄 with last technology's 😎
AMD B450 chipset :
*4 When the M.2_2 is occupied by M.2 device, PCIe x16_1 will run at x8 mode.
