[SOLVED] Building a computer 2022
TheRealBooBam
Commendable
Feb 17, 2019
22
Hi,
I'm planning on building a computer at the end of this month and don't really know what parts to pick for my specific needs.
I want to build a computer that can handle games like Rust, Escape from Tarkov, PUBG etc, etc.
I would also like to stream on discord while playing games.
I'm using a 144hz monitor with 1920x1080 and i don't plan on playing on 1440p anytime soon.
I live in sweden and the budget as of right now is 16000 SEK ~ 1800 USD
I do have a old gtx 1070 i could use as a placeholder for the time being if needed however, i do not know if bottle necking the cpu with a bad gpu will cause any damage after a while.
If i wait until late Febuary the budget is almost able to double, however i would rather not wait that long to upgrade.
A build that is "future proof" and will help me in the long run is a big bonus.
Any ideas?
Thanks in advance!
Hi,
If i wait until late Febuary the budget is almost able to double, however i would rather not wait that long...
Hi,
Any ideas?
Thanks in advance!
Something like this should be good...
PCPartPicker Part List
Type|Item|Price
CPU | Intel Core i7-12700K 3.6 GHz 12-Core Processor | kr4190.00 @ Komplett
CPU Cooler | Cooler Master MasterAir MA624 Stealth 67 CFM CPU Cooler | kr787.68 @ Amazon Sweden
Motherboard | Asus PRIME Z690-P D4 ATX LGA1700 Motherboard | kr2425.39 @ Amazon Sweden
Memory | Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory | kr1317.13 @ Amazon Sweden
Storage | Crucial P5 1 TB M.2-2280 NVME Solid State Drive | kr1069.69 @ Amazon Sweden
Case | Corsair 275R Airflow ATX Mid Tower Case | kr699.00 @ Amazon Sweden
Power Supply | Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply | kr1049.00 @ Amazon Sweden
| Prices include shipping, taxes, rebates, and discounts |
| Total | kr11537.89
| Generated by PCPartPicker 2022-01-11 11:44 CET+0100 |
All good quality parts included.
Type|Item|Price
| Total | kr11537.89
this seems like a good build but i have some questions,
is it worth upgrading the ssd to a "Seagate FireCuda 530 1 TB" and what would you do about the GPU
Wait a few weeks for the i7 12700F and B660 DDR4 boards to show up on European hardware sites. This board in the link down below should retail for right around $140 - $150 USD if I had to guess.
https://www.gigabyte.com/us/Motherboard/B660M-GAMING-X-AX-DDR4-rev-1x
This board down below has a better audio codec and VRM's hence the cost. The boards in this post are just two examples of several B660 DDR4 boards.
https://www.newegg.com/p/N82E16813145373
GIGABYTE B660 AORUS MASTER DDR4 $209.99
https://www.gigabyte.com/Motherboard/B660-AORUS-MASTER-DDR4-rev-10#kf
This is that cpu on a US site.
https://www.newegg.com/intel-core-i7-12700f-core-i7-12th-gen/p/N82E16819118359
Intel Core i7-12700F $329.99
You can probably get by with a cheaper cpu cooler but if you choose to run that cpu with the power limits off then this one is a good choice seeing how that cpu can reach 210w.
https://www.amazon.se/BEQUAB-BK022-Quiet-Kylare-Svart/dp/B07BY6F8D9/
Be Quiet! Dark Rock 4 Pro 250W TDP 798,49kr
https://www.bequiet.com/en/contact/lga1700mounting
Be Quiet! LGA-1700 mounting kit
2x16GB set of either 3200mhz or 3600mhz RAM. I'm just using this Kingston set as an example.
https://www.komplett.se/product/119.../minne/kingston-fury-beast-ddr4-3600mhz-32gb#
Kingston FURY Beast DDR4 3600MHz 32GB (2x16GB) 1 290:-
https://ark.intel.com/content/www/u...2700f-processor-25m-cache-up-to-4-90-ghz.html
i7 12700F + B660 DDR4 > AMD Ryzen 7 5800X
View: https://www.youtube.com/watch?v=ydgN4W97Esk&t=708s
yes it is worth upgrading,(compared with speed)
For a Gpu try to get one for your budget :) (find one on the net and post the link here :) )
refer to this :) >> https://www.neoseeker.com/Articles/Hardware/Guides/neoseeker-high-end-gaming-pc-build-dec-2019/
For your intended purpose it doesnt make a difference, but if you still want then this has same specs and cheaper...
BrandModelInterfaceForm FactorCapacitiesControllerConfigurationDRAMHMBNAND BrandNAND TypeLayersR/W (Up to, in MB/s)CategoriesNotes (*)Product PageProduct Page 2
CorsairMP600 PRO XTx4 PCIe 4.0/NVMeM.21TB-4TBPhison E18Triple R5 + CoX, 8-ch, 4-CE/chYesN/AMicronTLC1767300/6900Prosumer NVMeHeatsinkMP600 PRO XT
SeagateFireCuda 530x4 PCIe 4.0/NVMeM.2500GB-4TBPhison E18Triple R5 + CoX, 8-ch, 4-CE/chYesN/AMicronTLC1767300/6900Prosumer NVMeOpt. heatsinkSeagate FireCuda 530
Type|Item|Price
Storage | Seagate FireCuda 530 1 TB M.2-2280 NVME Solid State Drive | kr2160.89 @ Amazon Sweden
Storage | Corsair MP600 PRO XT 1 TB M.2-2280 NVME Solid State Drive | kr2069.48 @ Amazon Sweden
| Total | kr4230.37
| Generated by PCPartPicker 2022-01-11 12:58 CET+0100 |
The Corsair is better because it is cheaper with the same specs and comes with a robust heatsink, unless you have a better deal.
Not a good idea to buy GPU now. Use your 1070 for a while then make a decision.
Reactions: Dean0919
Type|Item|Price
| Total | kr4230.37
I agree on waiting on GPU, but i wanted to ask what GPU i should look for and at what price it would be worth buying, any idea?
Above build will be a solid foundation to whichever card you want to acquire, anything from mid to top tier from this and coming generation. Given the current situation its difficult to predict a price but this recent article should give you some idea...
