Building a molex connector out of a sata power connection
Naimdor
15
Hi guys,
I just bought a new graphic card (radeon 6850).
It comes with one 4 pin molex connector to 6 pin pci-e.
My problem is that my power supply does not have a molex connection, only sata power connection.
My idea was to build an adapter by cutting the last sata connection head from the string and connect it to a molex head.
So I figure out that in need to connect red wire to red wire and yellow to yellow, but what about the black cables?
Does it matter which on goes where?
Thank you
yes the black is the ground and most important actually.
if you're feeling really crazy just cut off the sata and molex connectors and hard wire the yellow to yellow and blacks to blacks together; all the PCI-E connector uses is the 12volt and the ground.
ok, now please know what i am telling you is VERY risky if you do not understand.
you can use the ONE black wire from the sata and use it to connect BOTH blacks from the PCI-E. it is called sharing a ground.
if you are wiring a low amp/watt card this is ok. but if it draws quite a bit of power, then it is extremely risky and can cause severe damage to the WHOLE system. please do NOT do it.
i am sorry i was not correct thinking 1 black on the SATA.
that picture is exactly what i think you could do. :)
and it is good if none of the other sata connections are being used on the same wire for a hard drive..
