Building First PC
mmsmm
62
Hey guys i am going to be making my first PC.
This is what ive came up with:
What do you think? any parts i should change?
Case: Coolermaster HAF 932 Black/ Titanium Tower Computer Case (£99.58)
http://www.scan.co.uk/products/coolermaster-haf932-black-high-air-flow-tower-case-w-o-psu
MotherBoard: Gigabyte GA-P67A-UD3-B3 (Version B3) Intel P67 Express Socket 1155 Motherboard (£99.20)
OR SHOULD I GO Z68 for MOBO?
CPU: Intel CPU Core i5 Unlocked 2500K Sandy Bridge Quad Core Processor (£167.98)
[URL="http://www.scan.co.uk/products/intel-core-i5-2500k-unlocked-s1155-sandy-bridge-quad-core-33ghz-gpu-850mhz-6mb-cache-95w-retail"]http://www.scan.co.uk/products/intel-core-i5-2500k-unlocked-s1155-sandy-bridge-quad-core-33ghz-gpu-850mhz-6mb-cache-95w-retail
GPU: MSI HD 6870 HAWK AMD Radeon Graphics Card with Twin Frozr III fan - 1GB (£150.82)
http://www.scan.co.uk/products/1gb-msi-hd-6870-oc-hawk-with-twinfrozer-iii-4200mhz-gddr5-gpu-930mhz-1120-stream-processors-dvi-hdmi
PSU: Antec True Power New 650W Modular Power Supply PSU 80Plus Bronze SLi (£69.18)
http://www.scan.co.uk/products/650w-psu-antec-truepower-new-modular-82eff-80-plus-bronze-sli-crossfire-eps-12v-quiet-fan-atx
RAM: Corsair Memory Vengeance Red 8GB DDR3 1866 Mhz CAS 9 XMP Dual Channel Desktop (£56.16)
http://www.scan.co.uk/products/8gb-%282x4gb%29-corsair-ddr3-vengeance-racing-red-pc3-14900-%281866%29-non-ecc-cas-9-10-9-27-xmp-15v
SSD: Crucial RealSSD M4 64GB - Solid State Drive - CT064M4SSD2 (£77.57)
http://www.scan.co.uk/products/64gb-crucial-realssd-m4-25-ssd-sata-iii-6gb-s-mlc-flash-read-507mb-s-write-290mb-s-new-version
HDD: Samsung 1Tb Spinpoint F3 Hard Drive - HDD (£44.38)
http://www.scan.co.uk/products/1tb-samsung-hd103sj-spinpoint-f3-sata-3gb-s-7200rpm-32mb-cache-89ms-ncq
DVD: DVD PLAYER - SATA 22x DVD Writer SAMSUNG SH-S222AB/BEBE (£13.86)
http://www.scan.co.uk/products/samsung-writemaster-sh-s222ab-bebe-22x-dvdr-12x-dvdr-dvdplusrw-x8-rw-x6-sata-black-oem
TOTAL COST: £776.95
dont get a gigabyte board they run the old BIOS. there are Asrock boards out with UEFI and 8x/8x lanes, the Asrock z68 extreme 3 gen3, thats what I would get as a budget crossfire board. It will also support intels Ivy bridge CPU's and pcie 3, which is another bonus over the gigabyte. If this is a gaming PC i would trade the SSD for a beefier graphics card. The 650w PSU you picked is very good and will run 2 x 6870's and even 2 x 6950's. Start off with a good vid card like the 6970 and dont bother with the ssd, if you really get frustrated with load times then get an SSD later on.
850w for dual 6970's
750w for dual 6950's
650w for dual 6870's
Also what's your budget, do you need Windows 7, and do you plan on doing all your shopping at scan, or can other sites like Novetech and ebuyer uk be used?
I get windows 7 pretty cheap cause im a student.
i would like to do it all there to keep things simple.
what would be better single 6970 or dual 6870s?
What Do you guys think of this new build?
Case: Coolermaster HAF X Black Tower Computer Case (£133.67)
http://www.scan.co.uk/products/cool...aming-tower-case-inc-side-window-usb3-w-o-psu
MotherBoard: Gigabyte SKT-1155 Z68A-D3H-B3 Motherboard (£106.42)
http://www.scan.co.uk/products/giga...6gb-s-raid-sata-pcie-20-(x16)-vga-on-board-at
GPU: XFX HD 6970 2Gb ATI AMD Radeon Graphics Card HDMI/DVI+ (£287.63)
http://www.scan.co.uk/products/2gb-...pu-880mhz-1536-cores-2x-mdp-dl-dvi-i-dvi-hdmi
+ Windows 7 - 64Bit
TOTAL COST: £956.85
ALSO would i need any extra fans or anything?
1 x 4pin ATX 12V
9 x 4pin Molex
2 x 6+2pin PCI-E Power
2 x 6pin PCI-E Power
1 x 8pin CPU +12V
1 x FDD Power
9 x SATA Power
also are they all connections i need for psu?
heh. It's a gfx card link you provided... :pt1cable:
Cases are more personal preference so very hard to say. I didn't go with HAF because it's just butt-ugly in my eyes... 😉
I've heard Lian-Li cases are very good and made of light-weight aluminum. Then there's their lower end Lancool series that are steel, heavier and a bit cheaper. I heard the Lancool Dragon Lord series are good, and was something I was considering too at the time I was fishing for a case.
I ended up with a Raven 2 Evolution case and I built my brother's comp with a Corsair 600t (both of them are the white editions). But in all honesty, I like the 600t because it's cable management is a bit better, smaller and lighter. But I like the look of the Raven more over the 600t. So, it's more personal preference.
As for an aftermarket cooler, you can get one now and don't need to worry about it later on if you decide to OC in the future. It'll also help keep your cpu cool too, which is not at all a bad thing. You can go with a CM 212+ (the most popular budget oriented cooler that does perform well).
