[SOLVED] Building my first PC, Is this build the best bang for buck and compatible with everything else?
Nov 10, 2019
PCPartPicker Part List: https://au.pcpartpicker.com/list/ZmwK4n
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor ($375.00 @ PCCaseGear)
Motherboard: Gigabyte B450 I AORUS PRO WIFI Mini ITX AM4 Motherboard ($194.00 @ Shopping Express)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory ($138.00 @ Shopping Express)
Storage: Samsung 860 QVO 1 TB 2.5" Solid State Drive ($159.00 @ Shopping Express)
Video Card: Gigabyte GeForce RTX 2060 6 GB GAMING OC PRO Video Card ($589.00 @ Austin Computers)
Case: Phanteks P300 ATX Mid Tower Case ($89.00 @ PCCaseGear)
Power Supply: Corsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply ($112.00 @ Shopping Express)
Operating System: Microsoft Windows 10 Pro Full - USB 32/64-bit
Monitor: Asus VG278Q 27.0" 1920x1080 144 Hz Monitor ($368.00 @ Shopping Express)
Total: $2024.00
Generated by PCPartPicker 2019-11-11 05:16 AEDT+1100
Also I'm not sure about the motherboard and deciding between an MSI B450 Gaming Plus Max(ATX) or the Gigabyte B450 Aorus Pro Wifi ((mini ITX)
That is a good build but I have changed your SSD to a NVMe Crucial P1 which is much better and faster and updated the power supply to a much better one though you could drop down....
Double check you do not need a BIOS update on that motherboard to get you CPU to work...
PCPartPicker Part List: https://au.pcpartpicker.com/list/zNRyk6
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($155.94 @ Amazon Australia)
Video Card: Gigabyte GeForce RTX 2060 6 GB...
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($149.00 @ PCCaseGear)
Total: $2057.94
Generated by PCPartPicker 2019-11-11 05:32 AEDT+1100
Reactions: I Must Be Quackers
The build will work fine as long as the motherboard BIOS has been updated new enough to use the 3rd gen Ryzen, you may want to ask the retailer if it's been updated before you buy.
Are you buying the ITX for the Wifi? There are some ATX boards that have Wifi or you could just use a adapter.
I was gonna grab the itx board cus of the wifi lol but if there are other ATX boards that are about the same price or cheaper id love to know lmao, new to everything about building computers.
Total: $2057.94
Thanks for that ur right its actually a lot better and much more worth the money spent, thanks a lot.
Wifi & cheaper.
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard ($143.00 @ Newegg Australia)
Total: $143.00
Generated by PCPartPicker 2019-11-14 09:56 AEDT+1100
Also from the looks of the CPU support list it ships with an updated BIOS.
https://www.asrock.com/mb/AMD/B450Mac/#CPU
