Hey there, we've just put together the computer, and the power seems to be working, as when we plug in a USB hub there is a red light on it turning on showing that there is power.
All the cords are plugged in correctly to our knowledge, but when we press the start button on the computer nothing happens, it's a blank as in no fans, lights anything. We tried pressing the power button on the motherboard but it still doesn't work.
We've also fairly certain that system panel header is hooked up correctly. So the power button really should be working.
The first time we tried it the light for the power flashed on quickly, and the monitor stopped showing the check signal cable message, but this was for a split second, and it is no longer doing this.
It is also unlikely that the hardware is broken because we bought it new a few days ago.
Is there anything we could be forgetting causing this problem?
