[SOLVED] Cable required to activate Corsair SP120 Pro ?
hadiahmed29
233
18
10,615
Hi guys so last week I had 10 fans installed in my system but the motherboard ran out of ports for it.
The computer guy told me that there is a specific cable which will be required to activate all the fans
I'll be attaching the male cable below he said he needs the female version of it with 2 wires in and 1 out which will be plugged in motherboard
What are these cables called?
Thank you
View: https://imgur.com/a/Bffvjfd
Thank you
He is suggesting you use a cable splitter but don't get more than 3 fans per MB connector.
Better solution would be something like this, a powered hub
https://www.amazon.com/ARCTIC-Case-Fan-Hub-Distributor/dp/B0887VG14J?th=1
Thank you
This hub will activate the RGB and run my fans as well?
I have these options available
http://www.gtstore.pk/detail/1st-player-hu1-argb-hub-for-rgb-fans-with-wireless-remote-4487.html
No. that's for fan motors only. For(a)RGB lights you need appropriate controller but lights use much less power so you can daisy chain those or use Y splitters.
He said that the Sata cable would power on your RGB but not the fan motors so I guess I need this fan controller to run my fans and use Sata cable for RGB lightning right?
