Regarding the Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15 Desktop Memory Kit - Black (CMK16GX4M2B3000C15) - I'm looking to use this memory along with the Gigabyte Z390 Aorus Pro Wifi motherboard. This memory is listed in the board's Qualified Vendor List (QVL) as supported.
I know that the i3 9100F has some limitations on memory speed. If I use this memory and motherboard with the i3 9100F, and choose the XMP profile in the BIOS, will the memory still be down-clocked to 2400Mhz, or will it still run at 3000Mhz, or maybe something in between? If it will be down-clocked to 2400Mhz I might as well buy the 2400Mhz itself which is a bit cheaper.
For reference this memory is here: https://www.amazon.com/Corsair-Vengeance-3000MHz-Desktop-Memory/dp/B0134EW7G8
Please let me know. Thank you.
